DIAdem
interpolate data points of a curve
I am looking for a method to interpolate data points on a non liner curve.
The method I am trying to emulate in MATLAB is y1 = interp1(x,y,x1)
Essentially I am trying to supply my interpolate function two components of a curve (x & y).  The x1 one value is an independent variable such as time.
Are there any built in features that would allow me to do this?
Tim
(5,074 Views)
Hi Smooth,
Have you looked through the options in the "Curve Fitting" palette of the DIAdem Analysis panel?  Or if you prefer a point by point linear interpolation, you can use the Linear Mapping function in the "Channel Functions" palette of DIAdem ANALYSIS panel.
Brad Turpin
DIAdem Product Support Engineer
(5,051 Views)
Brad
Linear Mapping does the trick!
Tim
(5,027 Views)
