DIAdem
is anyone else having a problem with 2-D graph of LVM data some x values showing up as negative values?
scrolled.pngI am trying to plot lvm data from a DAQ in Diadem 2011 and am getting what appears to be overlapping values and when I scroll to shrink the graphs, it appears the x values are negative for a part of the graph (which doesn't make sense because x=time).  It worked fine on Diadem 2010 - is my 2011 version corrup or is there a setting I have missed?
(4,142 Views)
Would it be possible to post one of your lvm files?
(4,130 Views)
Somehow attaching the file did not work. Could you zip it before attaching it?
(4,111 Views)
Hi mtgjbird01,
See if you can attach your LVM file to this post. If it's too big, perhaps you could just attach a portion of it or collect less data.
Michael Miracle
NI Americas | AE
(4,098 Views)
sorry - i can't seem to zip the file and won't be near the computer that created the lvm file for a while. thanks anyway
(4,067 Views)
