DIAdem
jpeg-export - metafile error - errorcode 2 or errorcode 0
i want to export my Report-Sheet as an jpeg from an serial analysis for every step. After the first step the jpeg-export fails with following error message: (in german) "Es befindet sich keinMetafile in der Zwischenablage. Fehlercode 2" or in english: "there are no metafile at the clipboard. error code 2" the failing command looks like this:
for i = 1 to 12
Call PICEXPORT("D:\MFriedrich\" & messname & "Kraftanzeige_" & k & "0kmh.JPG","JPEG",1,1024,,"RGB 24 YUV 444",100,"JPEG",0)
next
The files and folders do exist.
What can i do? I seems, that a temporary picture will not be create at the clipboard.
DIAdem 9.10.2345 ServicePack 2b
WinXP
Modul: Diadem-Script
(3,618 Views)
Hello!
I tried by my computer and could export in a for loop the Report in a JPEG without any error.
Could you post the whole code you are doing in the loop?
So I can try do reproduce the problem
Regards
Ken
(3,603 Views)
