DIAdem
legend width
I want to set the width of a legend using script.  I can set its position, but cannot influence its size, which appears to be adjusted automatically.  Usually, it is too small to be legible.  How can I do this?  So far I have being using (unsuccessfully) these varaiables:-
D2LegPosX
D2LegPosY
D2LegTxtSizeAut
D2LegSizeGlX
D2LegTxtType
D2CCurveLegTxt
D2LegDraw = true
Can anyone guide me please?  Obviously, I am missing something....
Thanks in advance
(6,319 Views)
Sounds like you legend size is still set to "Automatic legend size". Please change this parameter to "Fixed legend size" in the dialog and you should be able to adjust the legend width using variables in a Script.
Otmar D. Foehner
(6,315 Views)
Hi Otmar,
Thanks for the explanation.  Is there a way to change that option by script?  Then the macro containing it could be used by different users without each one having to make manual changes.....
Thanks!
(6,296 Views)
You can set that option with the following code.  This code was created given the name of the plot was 2D-Axis1.
Dim oCurveLegend, oLegendPosition
'------------------- CurveLegend ------------------------------
Set oCurveLegend = Report.ActiveSheet.Objects.Item("2D-Axis1").CurveLegend
'------------------- LegendPosition ------------------------------
Set oLegendPosition = oCurveLegend.Position
oLegendPosition.SizeMode = eLegendSizeFixed
Jesse S.
(6,276 Views)
Hi Jesse,
Thank you very much.
(6,274 Views)
You're welcome.
Jesse S.
(6,266 Views)
