DIAdem
linear mapping channel not monotonic
I am trying to map one channel onto another, but DIAdem tells me I can't because the time channel I am trying to map is not "monotonic." First, I don't understand what it means to say just my X axis channel is not monotonic. Second if the signal I am trying to map is not monotonic, I don't see how that prevents it from being mapped.  I have attached the file. I am trying to map and interpolate UUT/Y onto REF/Y.
Can anyone help me out with this?
(7,138 Views)
JoJo
When I was using the same function, I got the same error. In my case it was because the time channel had some values that went down instead of gradually increasing in values.  I would suggest that you look real close at the values in the time channels. (Sorry, I have not looked at your TDMS file)
In my case, I generated a time channel with guaranteed alway increasing values (therefore monotonic)  If your sample rate is consistent then that will allow the remapping function to work.
Paul
(7,108 Views)
I went back and looked more closely at the timestamps.  It turns out there was a problem with the logging system in the device I am using, and there is at least one point that appears after it's neighbor but is stamped as having happened a few milliseconds before, so you were right.
Thanks for the suggestion.
(7,051 Views)
