DIAdem
loading citadel database
i want to load data from citadel database to DIAdem data portal through scripting,i know for that we have to write some commands i learned about variable storageABS(key) but didn't understand how to use this for different traces in database. i tried by enabling the scripting & then loading data to data portal(manually), the script which i get after loading the data into the data portal is very difficult to understand & while running that script it's giving error "unterminated string constant" & i want to write script for loading the data in data portal so is there any way to understand the scripting for loading data from citadel database to data portal?
can any one help me please.
Nidhi
(4,011 Views)
one more thing is if we are doing scripting then it will fixed number of character in one line,what to do if we want ot extend the line(more than the character specified)?
(4,007 Views)
Hi Nidhi,
See my other 2 posts to you today, please.  Ideally, you would post re;lated questions to only one Discussion Forum entry, as opposed to raising the same related issues in 3 different posts.
Brad Turpin
DIAdem Product Support Engineer
(3,999 Views)
Thanks for your help, hope it will help me to sort out the problem.and sorry for sending same problem three times.
(3,991 Views)
