DIAdem
mark parameters in the table
hi,
There is a way to mark in color parameters that changes in the tables un the view tab like at the Example, script or something?
(4,834 Views)
Hi Stanger,
It is not possible to change the color parameters in the view tab. Please take a look at the forum I linked below that also explains this. I do believe it is possible to change the color of cells in the report tab. I am currently searching for more details on how to do this but wanted to make sure that was an acceptable solution for your application.
http://forums.ni.com/t5/DIAdem/View-Panel-Change-color-of-data-values-in-channel-table/m-p/1766064
Patrick H | National Instruments | Software Engineer
(4,812 Views)
Hi Guys,
Here's an example of conditional text coloring/formatting in a REPORT table.
Brad Turpin
DIAdem Product Support Engineer
(4,740 Views)
