DIAdem
multiple scales on Y with the one time axis
I have selected n y axes(linear) and in my initial post indicated I have 10.  I don't want to show all 10 axis scales.  Is there a way to turn off 9 off them.(VIEW)?  When I transferred the graph to REPORT it did it automatically for me.
I tried to attached the TDV file but the board would not let me upload a .TDV????
Message 11 of 13
(1,513 Views)
Okay.  I was just playing around and I wouldn't have expected this to happen but I do get only one scale when I select y-axis[LINEAR]. I was thinking this was more for the datasets and not just for the scale itself.
Message 12 of 13
(1,509 Views)
Hi Tweedy -
"N Y-Axes [Linear]" means that there will be one Y-Axis per graphed curve, up to N curves, so long as N <= 20.  If you want all curves graphed versus one single Y-Axis system, you should use the default setting of the 2D-Axis System, which is "Y-Axis [Linear]."
If any of your curves have very disparate Y-magnitudes / Y-ranges, it might make sense to use "Y-Axis [%]" instead, which will graph each curve relative to a scale representing 0-100% of its own maximum value.
Derrick S.
Product Manager
NI DIAdem
Message 13 of 13
(1,503 Views)
