DIAdem
one axis system
Option Explicit  'Forces the explicit declaration of all the variables in a script.
Dim MyFolders()
Call InitMyFolders
Sub InitMyFolders
  ReDim MyFolders(1)
  MyFolders(0)="C:\TEST DATA\dat files\"
End Sub
Call Data.Root.Clear()
Call DataFileLoad(MyFolders(0)&"C100227-6.DAT","DAT","Load") '... DataFilename,FileImportFilter,ImportAction
Call DataFileLoad(MyFolders(0)&"C100227-7.DAT","DAT","Load") '... DataFilename,FileImportFilter,ImportAction
Call PicLoad("Template")
 Call GraphObjNew("2D-Axis", "2DAxis1")
  Call GraphObjOpen("2DAxis1")
  Call GraphObjNew("2D-Curve", "2DAxis1_Curve1")
  Call GraphObjOpen("2DAxis1_Curve1")
    D2CChnXName      = "C100227-6/000000000000TI00"
    D2CChnYName      = "C100227-6/000000000000AC0D"
    'D2CChnYName      = "C100227-7/000000000000AC0D"
  Call GraphObjClose("2DAxis1_Curve1")
  '------------------- Curve list -------------------------------
  Call GraphObjNew("2D-Curve", "2DAxis1_Curve2")
  Call GraphObjOpen("2DAxis1_Curve2")
    D2CChnXName      ="C100227-7/000000000000TI00"
Call GraphObjClose("2DAxis1_Curve2")
Call GraphObjClose("2DAxis1")
Call PicUpdate(0)
When i run this code, It displays n- axis in report . i want it to be plotted on one axis. How do i do that??
If i double click on report, go to axis position and select one system and OK, It displays as i require. How do i automate it.??
(4,298 Views)
Hello Rash.patel,
If I run this code:
call PicDelete
PicDefByIdent    = 1
  D2AxisSystem  = "one system"
    D2CChnXName      = ""
    D2CChnYName      = "Temperatur_1"
    D2CChnXName      = ""
    D2CChnYName      = "Temperatur_2"
Call PicUpdate(0)
 it works fine on my DIAdem. The variable you are looking for is D2AxsSystem. You find those information by opening the dialog where to modify the parameter and opening the online help.
Greetings
Walter
(4,295 Views)
Hi Walter, Thanks for your help. Now i can see the graph in one axis system.
Option Explicit
Dim MyFolders()
Call InitMyFolders
Sub InitMyFolders
  ReDim MyFolders(1)
End Sub
Dim iCount
Call MsgBoxDisp("Please control Select MULTIPLE Data Files")
call FileDlgShow(DataReadPath, "DAT files (*.dat),*.dat", "Select File to Process...", true)
For iCount = 0 To Ubound(FileDlgNameList)
      Call DataFileLoad(FileDlgNameList(iCount))
'call PicDelete
 PicDefByIdent    = 1
Call PicUpdate(0)
This code works fine with dat files having 2 channels TI00 and AC0D mentioned in the script.
How can i modify the same script for any dat file having varying number of channels. For eg all dat files with 60 channels.Is it possible??
Am bad at programming, i dont know this logic works, whether i should mention all the channels in the dat file in my script or is there any alternative way??
(4,278 Views)
Hi Rash.patel,
You have two choices. You first option is to simply configure 60 curves in your TDR file, say referencing channels [1]/[1], [1]/[2]...[1]/[60].  Any missing channels will simply not be plotted.  Your second option is to use the same scripting approach you've alread posted, but loop over all the channels in the desired group and create a curve from scratch for each data channel.
Brad Turpin
DIAdem Product Support Engineer
National Intruments
(4,266 Views)
