DIAdem
order analysis cut short
I am still waiting for some answers for my questions after providing all the info related to the issue.
Message 11 of 15
(2,928 Views)
Hi ULIHZ,
I tried your data set with the posted "Joint-Time-Frequency-Order-Analysis Tool" and was able to compute the full rundown spectrum:
http://www.ni.com/tutorial/3549/en/
Brad Turpin
DIAdem Product Support Engineer
Message 12 of 15
(2,908 Views)
Thanks Brad!
Unfortunately, I couldn't.  I am using DIADem 2012 (standard?).  The order analysis toolboese are grayed out.
I was using the script (given in my earlier post) came with the code doing the analysis. Would you please give that a try at your place?
Message 13 of 15
(2,902 Views)
Hi ULIHZ,
The application you can download at the link I posted will work with DIAdem Base or Advanced or Professional.  Just like the script you have, it does not require the order analysis functions in the ANALYSIS panel to be active.  All DIAdem functions are available programmatically.  The different versions activate the interactive nature of various features, such as the ANALYSIS dialog for that function.
Brad Turpin
Message 14 of 15
(2,891 Views)
Sorry for the late reply!  Downloaded the app, will try and let you know.
Thanks!
Message 15 of 15
(2,818 Views)
