DIAdem
pdf export from diadem after update from v9 to v10
i've updated my diadem from v9.1 to v10.0 and can't export my reports into pdfs as i could with v9.1.  diadem run without problem and i can also see the diadem pdf printer in my printer list, but it doesn't work properly.I get the standard message of a succesful data transfer but my data doesn't exit.
Could someone help me?Did i do something wrong when installing the new version?
regards.
Patrick Etoumann
(4,037 Views)
Hi Patrick,
Are you using both DIAdem versions - 9.1 and 10.0 - on one PC?
If so, did you install the latest DIAdem 9.1 service pack?
Greetings
Walter
(4,029 Views)
Hi Walter,
thanks for your help.Unfortunately, it didn't work.
I've uninstall v.10 and just only install v9.1 with the expected service pack but i still have the same problem.
Just one question: my license is still not activated, could this be the problem?
regards
Patrick Etoumann
(4,003 Views)
Hello Patrick!
On some computers this problem was solved after deleting the 'DIAdem PDF Epxort' in the Windows printer list. DIAdem will reinstall it at the next start.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,996 Views)
