DIAdem
plugin split files
I wanted to know if there is any Data Plugin which can open *.001, *.002, ... kind of files.
Thank You.
Message 1 of 9
(6,992 Views)
Hi Maris,
My name is Marius from the NI AE team. I had a look around for the answer to your question. I found an old forum post that might answer your question, if you are using an MME data set.
Please let me know if this answers your question.
Kind Regards
National Instruments UK & Ireland
Message 2 of 9
(6,944 Views)
Hi Marius,
Thank you for your answer. I tried with both of them both only load the group name and not any channels :(... It loads channels when I use the AVL dataplugin, but the name of the channels loads incomplete.
Best Regards
Maris
Message 3 of 9
(6,916 Views)
Hey Maris,
I was more thinking of MME Import DataPlugIn or DTR_13499. Have you tried those?
Kind Regards,
Message 4 of 9
(6,901 Views)
Hi marispaulies,
Can you post a sample data set so we can try a few DataPlugins and tell you if any of them work for us?  If posting is not an option, you could instead email me a data set at brad.turpin@ni.com
Brad Turpin
DIAdem Product Support Engineer
Message 5 of 9
(6,899 Views)
those 2 that you mention are the both I tried, which where the ones recommended in the ols forums. 🙂
Message 6 of 9
(6,883 Views)
I can not send you any file. But I am sending you the way I see them
Message 7 of 9
(6,878 Views)
Hi marispaulies,
How did you produce these files?
Kind Regards,
Message 8 of 9
(6,852 Views)
Hi marispaulies,
I think it's interesting and odd that your first data file displays as a ZIP archive, while your other 2 data files look like plain old files.  Otherwise, your screenshot doesn't help me help you at all.
Brad Turpin
Message 9 of 9
(6,834 Views)
