DIAdem
polynomial fit of the data
I am trying to do a polynomial fit for some data, so far I have found the functions "ChnRegrXYCalc" and "ChnApprXYCalc" but I haven't found the way to choose the order of the polynomial fit. Is there a way to select the order of the polynomial fit?
Leo
(6,885 Views)
Hello Leillo,
There is a DIAdem ANALYSIS function that does multi-polynomial curve fitting. It's included in the Advanced and Professional Edition of DIAdem.
In the DIAdem ANALYSIS panel select "Curve Fitting" and then "Approximate"
In the dialog, select your polynomial, check the preview and then execute the function with "Calculate" or "OK".
Let me know if you have additional questions,
      Otmar
Otmar D. Foehner
(6,877 Views)
Hi Otmar,
Can you tell me how to translate that into VBS code? Is there a function where I can type the order I need to calculate the polynomial fit?
(6,871 Views)
(6,867 Views)
Hi Leillo,
If you're in an ANSLYSIS dialog, you can always click on the <Help> button at the bottom right of the dialog.  This will pop up a Help page that talks about how to use the dialog-- not what you want.  BUT if you look all the way at the bottom of that Help page, you will see a link to the command or commands behind that dialog, and they WILL show you how to call that functionality with a VBScript.
Brad Turpin
DIAdem Product Support Engineer
(6,825 Views)
How to fit a curve (polynomial) by forcing start and end point, from a given set of data points.
(3,107 Views)
Hi rarun,
I've checked with R&D, and I'm sorry to report that the approximation function in the DIAdem ANALYSIS palette does not support fixing certain points in the analysis, so that the resulting fit is constrained/guaranteed to pass through those fixed points.
I don't have a suggestion for you,
Brad Turpin
Senior Technical Support Engineer
(3,084 Views)
