DIAdem
problem of DIAdem Kernel
Hi evrybody
First of all I wish you a Happy New year for 2010.
Recently I have created some Script in DIAdem using several loop to calculate RMS, Filtered signals and FFT.
All my script worked perfectly until last week. Because when I run any of my script (not one in particular, and it work with other computers), a error message appears:
"Error message from DIAdem command Kernel:
Cannot generate the required number of channels."
And the message complete with the reference of the command.
My question are: Is The script abort because I have not enough memory in my hard drive?
or Is it my Random Access Memory which is sature?
Thanks for any answer
Regards
Pascal
(3,493 Views)
Hi Pascal,
Can you tell us the exact contents of command line that causes this error?  Or better yet post your whole VBScript.
Brad Turpin
DIAdem Product Support Engineer
(3,479 Views)
