DIAdem
problem when accessing Diadem via OLE
I've got two questions related to communcation with VC++ and Diadem via OLE.
I programmed the following lines in the Visual C++ environment
  ITOCommand *p_Diadem;
  p_Diadem = new ITOCommand;
  p_Diadem->CreateDispatch("DIAdem.ToCommand");
  while(!(p_Diadem->GetBInterfaceLocked()));
  _variant_t ValueT;
  p_Diadem->CmdExecuteSync(COleVariant("ScriptStart('V:\\Test.vbs')"));
  p_Diadem->TextVarGet("RootPropGet(\"Author\")", &ValueT);
  delete p_Diadem;
I call a script, which generates a new "Author"-description. When I step through the lines with the debugger and read back
the author (p_Diadem->TextVarGet("RootPropGet(\"Author\")", &ValueT);), ValueT includes the right description of the author.
But when I set a breakpoint at the "readback line" and run to this line without breaking before, the ValueT is undefined (,appears as {???} in the watch window).
It seems like a runtime error, when instanciating the object (CreateDispatch...).
Any idea, how to solve this problem?
Second question:
How I have to convert an Integer to the variant-datatype?
I wanted to transfer a parameter from C++ to a global variable in Diadem using the function
(Diadem->IntegerVarSet("Varible",_variant_t(1))), but there is a casting problem between const int and variant,
which mistake do I make?
kind regards,
JB
(3,629 Views)
Hello JB!
First question: Change
to
while( p_Diadem->GetbInterfaceLocked() )
  Sleep(100);
(the ! was wrong, GetbInterfaceLocked is in my interface, sleep improves the overall performance).
Second question:
Just make a (long) cast. I prefer to use this expression: COleVariant((long)1)
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,620 Views)
Hello Matthias,
Thank you for your helpful information,
but now I get a new problem, maybeyou have got an idea to this.
I am using the OLE interface to communicate with VC++ and Diadem.
I want to load parameters, before running a script-function.
So I decided, first run a script to declare the parameters (using
dim instructions) with command:
p_Diadem->CmdExecuteSync(COleVariant("ScriptStart('V:\\Main.vbs')"));
then I load the specific parameters with the command:
p_Diadem->CmdExecuteSync(COleVariant("MyVariable = 55")),
or
p_Diadem->IntegerVarSet("MyVariable",COleVariant(long(55)))
now I read back this parameters with command
p_Diadem->IntegerVarGet("MyVariable",&Value) //Value Type: _variant_t
but Value don't have the expected result, neither when setting the value in the script directly.
Can you tell me what's the problem?
Kind regards,
JB
(3,606 Views)
Hello JB!
See my reply to your other thread.
Matthias
Matthias Alleweldt
Twigeater?
(3,602 Views)
