DIAdem
"Diadem command line control"
Hi Midhunseelan O.S,
Excel does not register an ActiveX control for a Pie Chart that you can put on a DIAdem SUD dialog.  However, you can call the Excel ActiveX API directly from VB Script, thereby launching excel and possibly populating a pie chart programmatically.
Here are two links to help get you started:
Cheers,
David Goldberg
Software R&D
Message 11 of 15
(2,637 Views)
Is there a way i can load a file using command prompt in a running instance of Diadem Navigator ?
Message 12 of 15
(1,517 Views)
I want to pass list of mf4 files to DIAdem script through command line and export PDF report based on specific template for each.
What is the best way to do it?
Message 13 of 15
(1,317 Views)
My favorite way to process files from  command line, is to have the command line call a script and the script will expect a file to exist in a specific path like c:/users/public/temp/Filelist.csv
Then before you call the command line, you make the Filelist.csv file. The VBS will then read the CSV file and do what you have coded in the script.
Paul
Message 14 of 15
(1,309 Views)
Thanks!
Message 15 of 15
(1,305 Views)
