DIAdem
"Find" "ChnFind"-method cant use "<" in this example
English:
Hi all,
I'm new here but cant find a topic that looks my problem.
Im scripting in VBS at the moment.
My script searches for outliners and copy them to an new .txt document.
Basicly it work great with ">". But when I use "<" to compare the measurement-data with the limit
find returns "0" as answer. That means "nothing found".
Here a sample about my problem:
 Do 'While (ChannelNr < finalcount)
    ChannelNr =  ChannelNr+1
    laengemax =  ChnLength(Ch("[" & ChannelNr & "]/I_" & pruefling &"\15"))
    var       =  msgboxdisp ("ChannelNr =" & ChannelNr & vbCrlf & "ChnLength: =" & laengemax,"MB_OK", "MsgTypeInformation",0,2)
    intMyResult1   =  1
Hilfe für Schleifen-EXIT
    uebergabecount
=  1
    uebergabefind
=  1
    uebergabefind
=  chnFind("Ch(""[" & ChannelNr & "]/I_" & pruefling & "\15"") < " & iunten   , 1)
Do while uebergabefind <> 0
        morefail1
=  intMyResult1+1
        intMyResult1
=  chnFind("Ch(""[" & ChannelNr & "]/I_" & pruefling & "\15"") < " & iunten , morefail1 )
if morefail1    =  0 then AutoQuit
if morefail1    =  laengemax then AutoQuit
        pastefail1
=  CHV(intmyresult1,"[" & ChannelNr & "]/I_" & pruefling & "\15")
        timefail1
=  CHV(intmyresult1,"[" & ChannelNr & "]/Time")
        intMyHandle1
=  TextFileOpen((MyFolders(0) & "Fehlerprotokoll.txt"), eTextFileAttributeWrite )
        intMyText1
=  TextfileWriteLn(intMyHandle1,  "Zeitstempel:  " & timefail1 & "  Fehler für I < Grenzwert.   I=" & pastefail1 & "  !" )
TextFileClose(intMyHandle1)
'Hilfe für Schleifen-EXIT
        uebergabecount  =  uebergabefind+1
        uebergabefind   =  Find("Ch(""[" & ChannelNr & "]/I_" & pruefling & "\15"") < " & iunten , uebergabecount )
    loop '
Grenzwert1
loop
Until  (ChannelNr  =  finalcount)'Channel
If anyone has an Idea, please inform me (=
Thanks a lot.
sincerely Michael
(4,554 Views)
Hi MichGer,
could you please supply some more information on your environment?
- Which version and edition do you use?
- Which operating system?
It would be very helpful, if you posted an example that is executable in order to reproduce the behaviour.
Thanks in advance.
Martin
(4,513 Views)
Hi again,
Yea I use VER 14.0.0
And my Operatingsystem is WIN 7
(4,411 Views)
