DIAdem
"Invalid Channel Name Used In The Command" but the Name Is Not Even In The Command
ERROR:
Error in <DataFilter_1.VBS>(Line164, Column 1):
Invalid channel name "[43]/Torque_Ratio" used in the
"ChnNovHandle("[43]/Speed_Ratio", , "SetValue", "X", "FALSE", "TRUE", 0)" command.
The command mentioned (Line 134) doesnt even include the [43]/Torque_Ratio and is given below:
Call ChnNovHandle(Data.Root.ChannelGroups(43).Channels("Speed_Ratio"), , "SetValue", "X", False, True, 0)
The faulty line doesnt even have the so called incorrect channel name in it. All the channels have been created before. What could be the problem?
(1,839 Views)
Something is incorrect with your channel reference.  It would be helpful to see an image of the Data Portal.
Try adding the following command prior to the Call ChnNovHandle() command:
Call LogFileWrite(Data.GetChannel("[43]/Speed_Ratio").GetReference(eReferenceNameIndex))
Also try replacing the index number for the channel group with the name of the channel group.  Ex.
Call LogFileWrite(Data.GetChannel("ChnGrpName/Noise_2").GetReference(eReferenceNameIndex))
(1,799 Views)
