DIAdem
"PicPDFExport" used in LabVIEW has been deprecated in DIAdem 2020 but the replacement "Call Report.Sheets.ExportToPDF" doesn't work.
I have been using the "PicPDFExport" command remotely using LabVIEW and the DIAdem connectivity toolkit to create PDFs from LabVIEW after running a script.  After upgrading from DIAdem 2017 to 2020 I found the command has been deprecated but the recommended replacement "Call Report.Sheets.ExportToPDF" doesn't work either.  Any suggestions?  Below is a pic of the LV code and error from DIAdem.
(1,410 Views)
A simpler question would be how can I use the LabVIEW "DIAdem Run Automation Command.vi" to send the "Report.Sheets.ExportToPDF" command to DIAdem?  I have tried several variations without success, each time DIAdem reports an error stating it is a undefined command.
(1,366 Views)
