DIAdem
real-time low-pass filtering in diadem-dac
I'd like to realize a 'real-time' filtering of a sensor signal by means of a low-pass filter. The processed/filtered signal should be instantaniously used for another process. How could I manage this functionality in Diadem dac. The predefined filters that are already available as blocks are not useful for my application. Any suggestions are welcome.
Cheers
Nils
(3,871 Views)
Hi Nils,
can you give a little more information on what you are trying to accomplish?
Why is the filter block not applicable in your situation?
What is the other process? What loop rates do you need to realize?
Hope I can help you better with these informations.
Cheers,
David
(3,848 Views)
