DIAdem
recording mode
Hi together,
I have created a Menu (next to File,Edit,...e.t.c.) with different submenus, which are linked to .vbs files.3
When i enable recording mode in script. and click one of the submenus, the script which is recorded is:
Call SCRIPTSTART("C:\Temp\MenuAdd.bMenuFctDo.vbs","",0) '... FILEDLGNAME,VBSPROCNAME,AUTOOBJLETOPEN
It doesn't record the routine that i call or the vbs file i call but a vbs file named: "MenuAdd.bMenuFctDo.vbs". this file seems not to exist either.
What is the reason behind this? any solutions?
thanks in advance
kaan
(3,710 Views)
Hi kaan,
I need some more info what exactly you are doing. Please, can you provide me the script with the menu declarations?
Greetings
Walter
(3,690 Views)
Hi Walter,
here is the file in which i add the menus to DIAdem. (see abb.vbs)
thanks in advance
(3,680 Views)
Hello Kaan!
In DIAdem 10.1 the teach in (record mode) gives the right result, in DIAdem 9.1 not!
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,676 Views)
