DIAdem
sample for how to use DirLstWrite
I am looking for a sample how to use DirLstWrite. I took a DIAdem training course at the end of March in Michigan for 5 days, my teacher's name is David xxx. He supposes to send me an exsample. I have not received it. Does anyone know his email? My email is limingzhou2002@yahoo.com
(3,652 Views)
I don't know who the person was that was teaching the class in Michigan, but here is an example of how to use the DirLstWrite command in DIAdem:
Call DirLstWrite("C:\Datafiles","Test*.dat","filename","test.lst",0)
Here is a description of the different items that this command is made off:
Call - VBS function, calls a DIAdem function
DirLstWrite - Command for storing file names in an ASCII file
"C:\Datafiles" - Directory in which to search for the data files that need to be put into the LST file
"Test*.dat" - Parameter to describe the file name(s) that need to be put into the LST file
"filename" - Parameter that determines how the results will be sorted in the LST file (by file name, by file leng
th, by extension, by date/time of creation)
"test.lst" - name of the LST file
0 - Parameter that determines if the files found with the DirLstWrite function will be added to an exisitng list file or put into a new file (if a file of the same name already exists, it will be overwritten)
The result of the above example will be this:
Test1.dat
Test12.dat
TestA.dat
TestC.dat
I hope this helps. Please let me know if you need additional information.
Otmar
Otmar D. Foehner
(3,652 Views)
Hello Liming!
I'm David McClelland, the instructor from your DIAdem class. I'm attaching to this posting two different DIAdem VBScripts that you can use to get filenames:
load_multiple_dats.VBS - uses FileNameGet() to allow the user to pick .DAT files through a dialog, then imports those datafiles.
load_multiple_dats_dirlstwrite.VBS - uses DirLstWrite() to automatically find a list of .DAT files, then imports those datafiles.
I'm sorry I didn't get these examples to you sooner!
David Mc.
NI Applications Engineer
(3,652 Views)
