DIAdem
save View on event independent from layout
Hello all
I am trying to program additional  right click menu options in VIEW but as far as I know, each time I use the AddUserCommandToEvent Command and add it to View.Events.OnShowingContextMenu or View.Events.OnContextMenuPointSelected the settings are only saved in the current view layout.  Thus if I load a new layout, the settings are wiped and I have to re-add them.  Is there any way around this that anyone knows of?  Thanks
(5,181 Views)
Hi ben,
Try not using the "AddUserCommandToEvent()" command.  Instead make a direct and exclusive assignment, like this:
View.Events.OnShowingContextMenu = "NameOfUserCommand"
If you want to have this assignement persist between DIAdem launches, then save the Desktop.DDD file.
Brad Turpin
DIAdem Product Support Engineer
(5,157 Views)
