DIAdem
saving channel names after deleting internal data
i wrote a Diadem-Script which shows a dialog-box where you can choose a channel name and enter the new channelname in another box and it will rename the channel and it works perfectly.
Now I would like to save the renamed channelnames because I have a lot of data which contains the same channels and I dont want to rename them all the time I load new data to Diadem, so it would be nice to have a saving option which remembers which channel names where changed and what the new channel names are, so I dont have to repeat the renaming process?
Do I have to write a Plugin for that or does something like that exists?
thanks
(4,240 Views)
Hi question,
DIAdem 2015 and previous versions do not have a built in mechanism for channel renaming.  My best suggestion is to export those channel renaming choices to an ASCII file that you can read back in next time the SUDialog is launched.
Sorry,
Brad Turpin
DIAdem Product Support Engineer
(4,216 Views)
ok thx
(4,213 Views)
