DIAdem
script ends after calling and running an object
I have a script that is not looping through an object as I expect.  It is likely something easy that I am overlooking...
Without posting exact code it is something like this:
For Loop1
    For Loop2
         Call Object
Object
    Sub 1
    Sub 2...
End
The nested For Loop2 only cycles one time and after the object code is executed the script finishes without error.
Any thoughts?
(4,647 Views)
You posted to the Diadem Idea Exchange which is for ideas to improve Diadem.  Your message sounds like an ordinary question asking for help.
I've asked the moderator to move it to the appropriate message board.
(4,644 Views)
Option Explicit
dim k : k = 0
dim obj : set obj = new CAbc
dim i : for i = 1 to 3
  dim j : for j = 1 to 5
    k = k + 1
    call obj.def()
MsgBox k
class CAbc
  sub def()
    k = k + 1
  end sub
end class
If your Code looks like this it seems to work like expected.
(4,628 Views)
