DIAdem
script to make chanel name a variable
HI,
I'm pretty new to writing script but am totally stuck on this.
I'm trying to write a spript to create a time channel based on sampe rate (the equation is simple) but the part where i get stuck is every time i load a different set of data my script is stiff refererencing "channel group2" so what i need is an input button/drop down box.....etc to sellect what channel group it should be using.
Any ideas?
Steve
(5,213 Views)
Hi Steve,
I am Ed from National Instruments Technical Support. I am happy to assist you with your request today. I'd just like to clarify, are you wanting to have this functionality in DiAdem rather than LabVIEW?
From what I can tell so far you could use a numeric control such as a dial, convert the numeric to string in your script and then concatenate this number to your channel name. You could also store your channel names as a string array and have a script acquire the string in the array at the given position, input from a numeric dial. Both methods can then be executed using a button. The input button is available under Visual -> Manual Instruments, which the numeric dial is also located in.
I hope that this is helpful and if you have any questions regarding your query please don't hesitate to ask.
Best Regards,
Ed
(5,141 Views)
Hi Steve,
If you want to create a script that always adds a time channel for the most recently loaded data set, then you can use the "Active Group" in your script:
Set Group = Data.Root.ActiveChannelGroup
Set TimeChannel = Group.Channels.Add("Time", DataTypeChnFloat64, 1)
Call ChnLinGen(TimeChannel, 0, LastXvalue, XvalueCount, "s")
Brad Turpin
DIAdem Product Support Engineer
(5,089 Views)
Thanks Brad,
That looks useful
(5,067 Views)
Thanks Ed,
I'll give that a go this afternoon. and let you know how i get on
(5,064 Views)
