DIAdem
signal start point
Hi together,
I am preparing evaluations for the acquired measurement data and one of the evaluations is : finding the start point of a trigger signal. I checked DIAdem functions but couldnt find any related functions, examples, etc. I attached a picture of the trigger signal , and the point I have to find automatically is shown with an arrow.
I would appreciate if you could tell me where to start, how to approach the problem
thanks in advance
Kaan Oenen
(3,470 Views)
Hello Kaan!
The find should be the right command to solve your problem. You have to define a condition wich must be fullfilled for the sample you want to find. In your case it could be a absolut value or (as I prefer) a percentage of the maximum value of the channel. If there is a offset in the signal (I can't see it in the image) you have to add it.
Example: nTriggerIndex = find( "Ch('Trigger') > (0.01 * ChnValMax('Trigger'))" )
Your signal looks pretty good. In other cases you have to smooth (e.g.) the signal to eliminate spikes, etc. in advance.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,451 Views)
