DIAdem
square root of a channel
I am trying to use Diadem and still learning to do basic calculations.
Given a channel containing several values. How do I calculate that will give me another channel giving corresponding square root of values in original channel..?
Thanks. Himanshu.
(4,644 Views)
Accepted by topic author rajoria
In the Analysis panel you can bring up the calculator and enter the following equation Ch("[1]/results" )=Sqr(Ch("[1]/baseVals" )).
If you are doing this in script you can use the following.
Call ChnCalculate("Ch(""[1]/results"" )=Sqr(Ch(""[1]/baseVals"" ))" )
Hope this helps.
Message Edited by waynecj7 on 05-07-2009 08:51 PM
(4,636 Views)
