DIAdem
suddlg
hi!
how can i use parameters in my suddlg??
i've got an string array in my *.vbs and i want to use this array in my dlg...
chris
(3,769 Views)
Hi Chris
The SUD?s are a self-contained VBS unit to create scriptable dialogs. To communicate with the VBScript ? where it is called from ? you must use DIAdem variables or self defined user variables. In your case the special variable type enumeration (Größenliste) could solve your problem. The enumeration variables are string variables defined in a text file.
I hope this will help you.
Greetings
Walter
(3,769 Views)
