DIAdem
time frequency order analysis VBS Script
I have used demo 2015 32 bit Diadem before purcahsing software for 2015 Diadem.
I have used time requency order analysis VBS script for finding RPM from tach signal on Bentley probes.
It worked well but when I bought Diadem software and try to convert RPM from tach signal using this script, I get the following error in the VBS script.
See the attachment.
Let me know what is the issue in fixing this error in VBS script.
JonYeon Oh
(4,552 Views)
Hello Eureka1,
„naviwfimport“ i spart of the compatibility settings of the DIAdem 32 bit versions. If you installed the 64 bit version of DIAdem 2015 all compatibility settings are not supported anymore.
I checked the possible options of „naviwfimport“ with DIAdem 2015 32 bit and it worked fine (and I have installed the 32 bit version and the 64 bit version in parallel).
Greetings
Walter
(4,544 Views)
I have asked IT to install 32 bit on my computer and will run teh scirpt file as you have suggested.
If I keep having a problem, I will let you know.
(4,534 Views)
