05-12-2016 08:35 AM
I'm trying to create a DataPlugin for reading .txt-files. The values of each desired channel are arranged in rows (lines in the txt-file). The collums are separaded by tabulators.
I can't figure out how to set the data arrangement in DIAdem 2015s DataPlugin-Wizard.
Here's a Quick example:
####EXAMPLE.TXT#################################################
#Header - ignore this line
value0_1 value0_2 value0_3 value0_4
value1_1 value1_2 value1_3 value1_4
I want all value0_x to be in channel 0.
All value1_x should be in channel 1.
I hope understand what I am looking for.
Thank you in advance!
Solved! Go to Solution.
05-12-2016 12:46 PM
I am not sure if it can be configured in the wizard but it can be written by a few lines.
Store this code into an new created DataPlugin. (Settings->Extensions->Dataplugins)
Option Explicit
Sub ReadStore(File)
File.Formatter.Delimiters = vbtab
File.Formatter.LineFeeds = vbcrlf
file.Formatter.CommentSign = "#"
dim groupObj : set groupObj = root.ChannelGroups.Add("group")
do
dim chObj : set chObj = groupObj.Channels.Add("channel_" & groupObj.Channels.Count, eR64)
dim nextVal : nextVal = File.GetNextStringValue(eR64)
dim i : i = 1
while not isempty(nextVal)
chObj(i) = nextVal
i = i + 1
wend
Loop Until not File.SkipLine
End Sub
Should read files of the form
#Header - ignore this line 0.1 0.2 0.3 0.4 1.1 1.2 1.3 1.4 2.1 2.2 2.3 2.4
05-13-2016 01:56 AM
I was wondering because the ASCII Import Wizard (not included in my version of DIAdem for some reason) gives the option to choose the data arrangement. http://zone.ni.com/reference/en-XX/help/370859J-01/gfsascii/ascii/hidd_step1/
Anyway, your script worked perfectly for me. Thank you so much!
05-13-2016 08:53 AM
The ASCII and Excel DataPlugin Wizards are available in the Advanced and Professional versions of DIAdem, the Base version does not support the Wizard features.
We are glad that Andreas' Script was helpful for your data set ...
Otmar
