DIAdem
unsupported offset correction id 257
Hi, Jeremy,
     I can’t get AVL Concerto software from website. Can you offer me a screenshot to capture the different between AVL software and DIAdem?
     It will better if you can give me a .csv file stores the groups and the corresponding channels you expected. Thanks.
Message 11 of 15
(2,745 Views)
here enclosed are the files showing the real difference between groups in Concerto and in DIAdem (jpg files for Concerto groups and a TDM file for DIAdem groups).
Of course, the same file has been open in DIAdem and Concerto.
Thank you
Jérémy
Message 12 of 15
(2,738 Views)
Hi, Jeremy,
    Thanks for offering me these information.
     Done:
           “PAR – Parameter” group
           “CAO” group
     Issues:
        1) I have no idea about “V”, “V_ABS”, “VOFFn”, “VOFFn_ABS”, “VOFFp” and “VOFFp_ABS” channels in Group1.jpg.
        2) The information of “FILE-Attached file”,“SYS – System Information”, and “SYNC- Selected Formula” groups can’t be get.
       Do you have some ideas about them?
   By the way, Could you offer me the original AVL file and its .csv file stores each channel’s data in Concerto software for testing? Thanks.
Message 13 of 15
(2,729 Views)
Thank you,
I attached the avl file as well as the .atf file containing the raw data (that we can visualize with notepad).
I checked in this atf file and for example V”, “V_ABS”, “VOFFn”, “VOFFn_ABS”, “VOFFp” and “VOFFp_ABS are written in there.
Let me know if you have the required information.
Jérémy
Message 14 of 15
(2,724 Views)
Hi, Jeremy,
      Thanks for offering me the attached files.
      I have looked into them, but we cannot get some requested data out of the file, such as “FILE-Attached file”,“SYS – System Information”, and “SYNC- Selected Formula”, “V”, “VBS”,…..
      And I have no idea why the channel data and length by the two Tools are different, maybe some missing information cause this.
      We can precede these only we get a documentation/Specification of the AVL file format.
      But we already have a DataPlugin for ATF files. You can use this DataPlugin to read ATF files you generate from AVL Concerto software. I hope this can help you.
Message 15 of 15
(2,711 Views)
