DIAdem
using getchannels to move channel to different channelgroup
I am trying to move all of my flow channels to group 4.  they are currently spread throughout several channelgroups.
Dim oMyChn
Dim oMyChannels
Set oMyChannels = Data.GetChannels("*FLOW*")
For Each oMyChn in oMyChannels
CallMsgBoxDisp(oMyChn.Name)
CallData.Move(data.Root.ActiveChannelGroup.Channels(oMyChn),Data.Root.ChannelGroups(4).Channels)
I am getting an error stating that "the argument transferred to Item must be either a string or an integer"
Can someone help?
(6,662 Views)
Nevermind.
I finally got it 🙂
Dim oMyChn
Dim oMyChannels
Call MsgBoxDisp(oMyChn.Name)
oMyChn.ChannelGroup.Activate
CallData.Move(Data.Root.ActiveChannelGroup.Channels(oMyChn.Name),Data.Root.ChannelGroups(4).Channels)
(6,655 Views)
Accepted by topic author 2Pale4TX
Hi Everyone,
I'd like to recommend the following alternative syntax as easier to debug and faster performing:
Set FlowChannels = Data.GetChannels("*/*FLOW*")
jMax = FlowChannels.Count
FOR j = 1 TO jMax
  Call Data.Move(FlowChannels(j), Data.Root.ChannelGroups(4).Channels, j)
NEXT ' j
Brad Turpin
DIAdem Product Support Engineer
(6,627 Views)
Thanks Brad.
I will adjust my script.
(6,625 Views)
