DIAdem
vas variable line continue
I am trying to define a text array in a .VAS file.  I tried to use the _ for line continuation in the variable definition, but DIADem does not seem to like this.  Anyway to do this, or do I need to define my variable all in one line?  Just easier to see it if each entry is listed down the page.
Example
myVar_ : A ('Text1', _
                    'Text2', _
                    'Text3') <'Text1'>
Thanks in advance,
Scott
(3,560 Views)
OK,
my error was not he line continue, it was the spaces I had in the elements.  Why can't the variable elements have spaces in them?
Example:
myVar_ : A('My text','Another text')  <>
(3,556 Views)
Hi Scott,
I just tested this out and I was able to add spaces in my text array. I simply took the example and changed it as such:
MyDays_ : A ('Fri day', 'Satur day', 'Sun day') <'Satur day'>
This worked for me. What is the specific error message that you are receiving in DIADem? The editor should give us a clue as to where the problem is.
Matt M.
NI
(3,526 Views)
