DIAdem
waveform different time frequency
I have two waveform channels that I would like to concatenate.
To do so, I convert them into pair channel and copy block of 2 into 1 for both time and data channels
Then I want to go back to a waveform of my new channel. But No! Not possible because the time frequency is not monotonous.
What can I do?
Thank you for your help,
Louval
Message 1 of 23
(7,672 Views)
can you upload an example? I tried it, without any problems. So to understand what you are facing it would be great to have some data.
Message 2 of 23
(7,649 Views)
The time and data channel are enclosed.
Thank you so much,
Louval
Message 3 of 23
(7,637 Views)
Thank you so much,
Louval
Hello Louval,
The TDM file format actually consists of two files, ad TDM and TDX. Please provide the TDX (binary data file) that belongs to this TDM (XML header file) or upload a TDMS version of the file (that has the header and data in the same file).
     Otmar
Otmar D. Foehner
Message 4 of 23
(7,632 Views)
Please, here they are.
Thank you,
Hugo
Message 5 of 23
(7,613 Views)
this does not help at all. We need the raw data and a description what you are doing.
Message 6 of 23
(7,609 Views)
What I wish is easy.
I would like to transform the channel 'time' and 'Vsum' into waveform channel but the time channel is not equidistant so I cannot use the function WfChnToChn.
What is not clear in what I am saying?
Louval
Message 7 of 23
(7,607 Views)
the solution here is to create a new equidistant channel. Maximum and legth must be same as by original channel. Then you are able to trasnform channels into waveform.
Simyfren
Message 8 of 23
(7,600 Views)
Ok, exactely but how I do that? This is my problem...
Thank you,
Louval
Message 9 of 23
(7,592 Views)
You simply have to genarate one and use it as the x-Channel.
Message 10 of 23
(7,589 Views)
