DIAdem
which version of DIAdem has DAC module?
Dear sir:
does somebody know which version of DIAdem has DAC module? DIAdem 8, DIAdem 9.0, 9.1 or others?
thanks
jing
(5,177 Views)
Hi Jing,
DIAdem is shipped in two revisions. Both revisions are designed to manage data, analyze them, create reports and automate this all using VBScript. Additional one DIAdem revision contains the DAC part. That means that every DIAdem version (8.0/8.1/9.0/9.1) can have the DAC part, it depends and the revision which was bought.
Greetings
Walter Rick
(5,157 Views)
a very good question !
There isn't much information about DIAdem DAC on this site which should be "the Home" of DIAdem.
DIAdem DAC is not even mentioned in the section "Other DIAdem Packages and Toolsets" !
Unfortunately, I know colleagues in the automotive business which ordered DIAdem and got the wrong installation package because of this nonexisting promotion of DIAdem DAC.
However, it has been know as;
- "DIAdem German version" (that does not refer to the language ...)
- "DIAdem Classic version"
but today I think you should use "DIAdem xx-edition with DAC Option", where 'xx' could be "Base"/"Advanced" or "Professional.
And then there are the -Official- "Other DIAdem Packages and Toolsets";
- Crash Toolset
- CLIP
- INSIGHT
best regards
Henrik
(5,143 Views)
here are some further details regarding DIAdem DAC which was sent from NI on a specific request from another colleague.
(The "device-names" refer to DIAdem 8.x !)
regards
Henrik
"I have finally had a reply from National Instruments regarding the DAC
bundle. They have stated that there are two version available:"
** DIAdem DAC Kit
Shell
VIEW
DAC
VISUAL
Multiple Courses
** DIAdem DAC Bundle
Shell
VIEW
DAC
VISUAL
Multiple Courses
Online Mathematics
Output/Control
Closed Loop Control
(5,139 Views)
Hi all,
Here is the complete list of the DIAdem 9.1 packages
Data Analysis and Report Generation Packages
DIAdem Base Edition
DIAdem Advanced Edition
DIAdem Professional Edition
DIAdem CLIP
DIAdem INSIGHT
Data Analysis AddOn Toolsets
DIAdem Crash Analysis Toolset
DAC Packages
DIAdem DAC Kit
DIAdem DAC Bundle
Available Combinations of Data Analysis, Report Generation and DAC packages
DIAdem Base Edition with DAC Kit
DIAdem Base Edition with DAC Bundle
DIAdem Advanced Edition with DAC Kit
DIAdem Advanced Edition with DAC Bundle
DIAdem Professional Edition with DAC Kit
DIAdem Professional Edition with DAC Bundle
Greetings
Walter Rick
(5,128 Views)
Are there any people using DIAdem without DAC? 😉
(5,101 Views)
All versions of DIAdem are available with the DAC module. You will have to specifiy that you want the DAC module when ordering the product. I suggest you get in touch with your local National Instruments office or representative, they should be able to help you with the ordering process.
Go to http://www.ni.com and click on "CONTACT NI" to find the closest office to you.
Otmar
Otmar D. Foehner
(5,083 Views)
