DIAdem
why is Diadem DAC is slow when reading over TCP/IP?
I wrote a small VB Script in order to comunicate with a Power Supply over TCP/IP in Diadem DAC, when I first run it, it works perfectly but if I I stop the program and run it again it is suddenly very slow. The only way to make it run normaly again is If I restart Diadem.
Am I closing my TCP/IP connection correctly? I am not sure what the problem could be.
thanks for your help
(5,074 Views)
sorry, but I've no answer to this question but nearly the same problem.
I wrote a small Qt socket app. which provides a TCP-Server sending every 100 ms.
I'd like to have Diadem plotting the sent data - I setup a 25 ms refresh rate but
the actual refresh lasts for about 1 s!! The sent values seem to reach Diadem
but the processing needs very much time, hence the processor load goes
directly to 100% which seems to be very strange. I put my code for reading
the values into the TCP script driver template - SFD_ReadChannel method.
If comment out the "oUDIM.read()" the refresh is as expected, with the read
command everything slows down dramatically?
What's the mistake?
Best regards and thanks for your help...
(5,030 Views)
Hello both,
I think in both cases you´ve forgotten to program a delimiter.
For this you will find the download for the Script-Daq-driver with examples on
http://digital.ni.com/softlib.nsf/websearch/DEA1C36806CDB7C886256E45003A32B9?opendocument&node=132070_US
Rebecca Fox
(5,013 Views)
Thanks for your help Rebecca, I just added a delimiter and a time out to my script
Call oUDIM.ParamSet("Delimiter",vbCR+vbLF)
 Call oUDIM.ParamSet("Timeout",100)
John Fautsch
(5,002 Views)
Can you repost the document that you have for the VBS script driver for a TCP/IP device? Thank you very much
(4,123 Views)
