DIAdem
xTable - change cell colour
In my xTable, this sub will change the colour of the dialog permanently when I change a cell entry:-
Sub XTable1_EventValSet(ByRef This, Row, Col, ByRef Cell) 'Created Event Handler
If Row > 0 And Col > 0 Then
Data.GetChannel(Col).Values(Row) = Val(Eval(Cell.Text))
Dialog.Color = vbcyan ' this works
End If
But, how can I change the background colour of just the changed cell permanently?
I can only get the cell colour to change temporarily using the examples from Diadem help (XTable1_EventDefaultColCtrlPreset and Cell.ForeColor)......
Any help is appreciated.
Thank you.
(2,958 Views)
Hello mrme,
did you try this:
  ' Dialog.Color = vbcyan ' this works
  Cell.BackColor = = vbcyan ' this works
End If
End Sub
Greetings
Walter
(2,927 Views)
Hello Walter,
Thanks for the response.   Yes, I have tried it, but no success. Neither Cell.BackColor nor Cell.ForeColor work.  There is no error message.  Xtable1.Refresh has no effect either.
I forgot to provide the version of Diadem  - it is 2018, 18.0.0f7097 (64 bit).
Thank you,
Thomas
(2,925 Views)
Accepted by topic author mrme
Hello Thomas,
Colors can only be set in the ...Get event. I've attached an example SUD.
Greetings
Walter
(2,891 Views)
Hello Walter,
Many thanks for the reply and example.
Thomas
(2,879 Views)
