DIY LabVIEW Crew Discussions
Newbie: I need a sample for a test
first time here. I'm testing a tool on a lab.
I have a measuring instrument, cyclically sending a measure by serial interface
(I do already have the sample to read it) and on command I need to collect samples at a frequency X and store it.
Once the capture is finish, I need to analyze the waveform to get some informations.
Then, I have to write results on Twincat (I do already have the sample to do it)
Do you have a sample for something similar to it ?
(sample a signal, store it, represent it, analyze it, get results)
(6,389 Views)
LabVIEW->Help->Find Examples will have something as simple as this, I'm sure
-fomine
_________________________________
You can do greater things with LabVIEW!
(5,996 Views)
