The DIY LabVIEW Crew is hosting a contest for the coolest home or hobbist applications that use LabVIEW. We will pick the winners based on how well you solved a DIY challenge, the origionality of your applicaiton, supporting content (like cool videos or good code), and most importantly feedback from the rest of the members of this crew.
Subscribe to updates from this group here and read the latest DIY stories, vote on the best application, and find out who the ultimate LabVIEW hobbiest is. All entries should be tagged with DIY_Contest.
Good luck!
1. Login or Register for the NI Community (www.ni.com/community) with your user profile
2. Join the totally awesome DIY LabVIEW Crew.
3. Create a document that describes your cool DIY Application by clicking on "Create A Document" under the actions box.
4. Click Tutorial as the document type and hit continue.
5. Title your application. Then, add a description of the technical details, including any photos or videos.
6.Attach any relevant VIs you want to share with the rest of the crew related to your application.
7. Scroll down and tag your entry with DIY_Contest
8. Publish your document.
9. The winner will be notified via the blog on the DIY LabVIEW Group.
