DQMH Consortium Toolkits Feature Requests
ChrisFarmerWIS
Create New DQMH Event - Private Request
Status: Released
Note that the implementation of this feature may be different from the one described in the feature request.
In the Create New DQMH Event... dialog panel, add a checkbox and label it "Make this a Private Request".
If this box is checked, the DQMH tools would create the request as normal, but store it under a virtual folder called "Private Requests" (Access scope = private)
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
DQMH Trusted Advisor
Automated Production Test Specialty Premier Partner
https://wiredinsoftware.com.au
1 Comment
Olivier-JOURDAN
Active Participant
Status changed to: Released
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
