‎05-01-2023 11:44 AM
Is there an easy way to add data to an existing event?
It's not too difficult to modify the payload typedef, and then the API VI, event handling case, and message handling case. But if there is a built-in way to do this I would gladly use it 🙂
‎05-01-2023 01:30 PM
There are currently no scripting tools to modify the parameters of an existing event. You have to make the changes manually as you describe.
‎05-01-2023 02:57 PM
Thanks Darren, I found that this idea has been proposed and declined already:
