DQMH Consortium Toolkits Discussions
Can't add parameters in cloenable module
I try to add parameters in cloneable module but encountered one problem.
There is a white square in place of cluster type in asynchronus call node, and i can't connect my Conf control. I have place my cluster parameter Conf in main Vi, connect them to the Main.vi connector, and drag and drop Main Vi connector in  Main VI Type--strict_vi_ref.ctl as requested.
Any idea of what's wrong.
Eric
(1,915 Views)
Is the parameter you're trying to add a private typedef in a library? Or does it contain private library typedefs? That's the only thing I can think of, other than your VI Connector Pane reference typedef having been disconnected somewhere.
Assuming those suggestions don't help, can you attach a simple module that demonstrates the issue?
(1,908 Views)
Accepted by topic author Eric_BOB
Oups. I have found my error. It's because i have connect one indicator and not a control to the Main Vi connector.
But i discovered than IDE  memorize connector for strict type Vi.
(1,905 Views)
