DQMH Consortium Toolkits Discussions
Check and Do vs. Try and Catch pattern in DQMH Event API Calls
Hello DQMH Fans
My apologies if this has been covered before but I noticed a possible anti-pattern in the API VIs which generate the DQMH events: before attempting to generate the User Event a check is made to confirm if the Event RefNum is valid. This assumes that nothing changes between the two actions and I doubt that anything actually would but...
It seems to me (and I am happy for others to disagree/correct me) that it would be better to just try and generate the event and then catch any error resulting from the User-Event RefNum not being valid. This avoids the minuscule issue where the RefNum goes invalid between the check and the Generate User Event call and the user is surprised by an Error Code 1 instead of the custom DQMH error 403681. The error-catching implementation could be done a number of ways but to illustrate what I mean, here is an example:
Cheers
John
(4,107 Views)
Hi John,
Thanks for bringing this up. I am looking at the code you proposed and it would still need some modifications. If there is an error coming into "error in", the code would "eat it up" and replace it with the Module Not Running error.
I have these two options, I will have the rest of the Delacor team take a look and we can prioritize if we should invest time on making this change given the small possibility of it causing a problem.
Modification 1:
Modification 2:
Do you have any preference between the two options?
Thanks for your trust in DQMH.
Fab
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
(4,010 Views)
Hi Fab
Thanks for the response and I completely understand that this wouldn't be a priority given all the other exciting features you have been developing.
I shall leave it entirely to you and your team to consider which error handling approach you prefer - I don't know if one will be easier than the others with regards to modifying and adding nodes with scripting. Of your suggestions, Modification-2  looks more like the NI style of wrapping everything in an error structure. It also prevents an unnecessary call to the Obtain Event Requests VI so think of the performance boost for the error case!
I hadn't spotted the issue with my suggestion - I thought that an error on the error-in terminal of the VI would flow to the error-out terminal via the error-precedence rules of the merge error node.
Cheers
John
(3,976 Views)
Hi John,
We will keep it in mind and
Cheers
John
You are correct, the error would flow to the error-out terminal via the error-precedence rules of the merge error node. This is actually why we have in that VI the input error flowing to the top input in the merge error node. My eyes stopped at the error case, that will teach me not to answer posts late at night 😉
Regarding the wrapping everything into an error structure, if you have not seen Darren's stop to brainless presentation yet, I totally recommend taking a look at that: http://bit.ly/brainlesslabview
Fab
dfd
(3,941 Views)
Hi Fab
Thanks for the clarification and especially for sharing Darren's Presentation. Finally, the yoke of oppressive 'best-practices' has been lifted and I am free to exercise logic and reason in all that I code.
Cheers
John
(3,923 Views)
Tell your friends. We'll eradicate those brainless LabVIEW practices, one programmer at a time.
(3,907 Views)
