DQMH Consortium Toolkits Discussions
Custom Tester Template (for custom module templates)
Just a quick question - can we create new API tester templates?
For example, if I wanted to have a tester VI with custom startup and teardown sections for all modules of a specific type.
(2,726 Views)
Accepted by topic author McQuillan
You can create a custom tester as part of a module template, but you can't create a template tester on its own.
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
DQMH Trusted Advisor
https://wiredinsoftware.com.au
(2,664 Views)
Cheers 🙂
It didn't occur to me that the tester was in the same source directory as the module! 🤦‍
I've been able to change the tester for some of my templates by editing/creating a new tester in LabVIEW Data\DQMH Module Templates\Source\<template>\Test <name> API.vi. Then (if required) change the name in the metadata XML file.
(2,569 Views)
