DQMH Consortium Toolkits Discussions
DQMH Module
I start learning DQMH. I am using LabView 2018 SP1 (32bit), I have installed DQMH package using VIPM.
When I started using DQMH in a new project, added a new module. I am surprised to see different module than shown in Videos and webinars.
It don’t have module type drop down menu to select module type singleton or cloneable. Also It don’t allow me to modify Overlay.
Please let me know why It is different, Is this due to LabView version?
Thanks and Regards.
(558 Views)
Something is wrong with either your DQMH install or your LabVIEW install. The Add New DQMH Module tool should not be broken. I suggest uninstalling/reinstalling DQMH first. If that doesn't work, you should uninstall DQMH, repair/reinstall LabVIEW, then reinstall DQMH.
(549 Views)
Thankyou Darren, I will try your solutions.
(517 Views)
If you continue to have issues even after following Darren's suggestions, please let us know which version of VIPM you are using to install
DQMH
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
(443 Views)
Hi Fab,
I am in the middle of something very urgent so I didn't reinstall my LabView. Once I will reinstall LV I will let you know.
Thanks a lot for your message.
(396 Views)
