DQMH Consortium Toolkits Discussions
DQMH Multi-thread Counseling
About multi-threaded programming to DQMH. For example, The following is my commonly used sequence structure. How can I transfer such an architecture to your DQMH, because I have multiple While loops in parallel, such as motor control, capture card control, gamepad control, UI settings, etc
Message 1 of 9
(4,890 Views)
Each of the 8 loops would be a DQMH module. The modules would communicate with each other through their public APIs (requests) and broadcasts. If any of the loops do periodic operations, you would want to add helper loops to those modules.
Message 2 of 9
(4,878 Views)
You mean I need to create 8 modules, but how do I ensure that the eight modules run synchronously? There is also how to display the data of the eight modules on a UI interface?
Jing
Message 3 of 9
(4,874 Views)
and you mean 8  loops would be 8 DQMH modules,and i do not need to use Queues to pass data streams?Some of my loops are producers and consumers, and queues are used. Isn't DQMH passed through this queue? I do not quite understand
Message 4 of 9
(4,870 Views)
Start here:
https://youtu.be/atpPRwPkwq8?list=PLZ3A_SIOKdQs73IjbtaWwCSqoxQfxlWj6
That should answer many of your questions.
The other videos on that channel are also worth watching.
And there is always the help.
https://delacor.com/documentation/dqmh-html/DQMHDocumentation.html
Sam Taggart
CLA, CPI, CTD, LabVIEW Champion
DQMH Trusted Advisor
Read about my thoughts on Software Development at sasworkshops.com/blog
GCentral
Message 5 of 9
(4,854 Views)
The infrastructure (queues, events, etc.) for communicating between the  DQMH modules is part of the framework. This is by design, so you don't have to create your own inter-process communication Have you looked at the online tutorials that are available? If not, I can recommend the following YouTube channels:
Tom's LabVIEW Adventure channel has a series of tutorials introducing the DQMH. This is probably a good place to start
https://www.youtube.com/playlist?list=PLmF-6jvwRvVOpNdPcRzskvnGbW79ug6AZ
This is the Delacore channel. You will find lots of information here:
https://www.youtube.com/playlist?list=PLZ3A_SIOKdQs73IjbtaWwCSqoxQfxlWj6
Hopefully you will find the above useful. Well worth taking the time to watch them.
David C
Message 6 of 9
(4,850 Views)
Can you provide me with an example? For example, the data collection program,see blew,how it transfer to DQMH?, the video I watched is difficult to understand.DQMH1.jpg
Message 7 of 9
(4,792 Views)
If you have DQMH Installed look at the DQMH Continuous Measurement and Logging (CML) example project.
Sam Taggart
GCentral
Message 8 of 9
(4,767 Views)
more details here: https://delacor.com/documentation/dqmh-html/DQMHCMLSampleProject.html
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
Message 9 of 9
(4,762 Views)
