DQMH Consortium Toolkits Discussions
DQMH woes
You might also check out this article, particularly the section on coupling.
https://www.sasworkshops.com/simple-dqmh-dos-donts/
The dependency issues might not be your main problem at the moment (ie. it might not be what is causing your errant message), but it definitely will become a problem in the future if you don't address it. You are just setting yourself up for a world of hurt.
Sam Taggart
CLA, CPI, CTD, LabVIEW Champion
DQMH Trusted Advisor
Read about my thoughts on Software Development at sasworkshops.com/blog
GCentral
Message 11 of 42
(1,739 Views)
FYI, Antidoc has an issue where the drawing doesn't always draw properly.  This has been fixed but not released yet.
Modules Overview diagram doesn't show all of the broadcast/request arrows (#134) · Issues · Wovalab ...
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
https://wiredinsoftware.com.au
Message 12 of 42
(1,731 Views)
@LVUser94  a écrit :
I downloaded the Antidoc via VPM and tried it. I pointed it to the Project lvproj file (which as about 2000 VIs, controls etc). It ran for a few minutes and created a "Project Documentation.adoc" file and a  bunch of over 1000 png files. I also installed the necessary Chrome extension to read the .adoc file (Ascidoctor.js). But after re-starting Chrome, and opening the .adoc file, all I get is an inscrutable text dump.
Did you get it to work with the diagram or not?
oops, I missed your reply. Sorry.
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
Message 13 of 42
(1,717 Views)
@LVUser94  a écrit :
Thanks Christopher for your help with AntiDoc. I kept adjusting all the settings (lallow File URLs, Pictures extensions etc) and loaded the .adoc file into multiple tabs in Chrome. After a lot of back and forth, on of the tabs in chrome the .adoc document finally turned into a nicely structured document with pictures. I don't know why it does not work right away and I am still having problems re-opening the file even though all the settings for the extension or correct. But it works sometimes, and when it works it is very impressive. It showed me in a picture all the DQMH module and their connections. I have attached the picture below.
Diagrams are generated through HTTP requests. I guess it's one of the reasons (the second one is the size of the document itself) you can have trouble with the rendering of the documentation. Sometimes you just need to wait to get the document properly rendered.
Olivier Jourdan
Message 14 of 42
(1,711 Views)
Thanks for pointing this out Chris.
I'm trying to publish a maintenance release that will contain the bug soon.
@LVUser94 if you want to run the beta version,, just let me know. I'd be happy to share the package.
Olivier Jourdan
Message 15 of 42
(1,710 Views)
Olivier, yes i am able to see the diagrams in the Antidoc file  in Chrome now.
Thanks for the offer to share your beta version. Once I solve the current DQMH problems I am having, I would like to do that.
Certified LabVIEW Developer (since 2005)
LabVIEW Developer since Version 2.0
Message 16 of 42
(1,698 Views)
Hi Joerg.hampel
Sorry for the delay in replying to your questions. I will try to answer some of them
first of all I'm sorry for your struggles with the software you inherited. I'd also be interested to hear why would not have gone with DQMH. It seems like a good fit from what you've described here so far?
I am an old timer, and I have developed actively in LabVIEW since version 2.0. I am also a certified LabVIEW Developer since NI first started certifications in early 2000s. So I love LabVIEW and love creating software with it. I am also somewhat set in my ways and have certain opinions on what constitutes good programming. It needs to be simple, elegant, and some what to the point. Fancy architectures are fine but if they just overwhelm the project then they are just getting in the way. Case in point, this project I have inherited is no more complex than many projects I have done in the past. Some have been more complex such as 16 station engine test stand with independent and parallel long term testing of small engines. Yet this project contains over 2000 VIs, has no clear architecture and just a huge mess to maintain. It takes a full minute to get going on launch and another minute to stop. Some times parts of it won't stop and I have to kill LabVIEW and restart even though I can't see what is running. It is not that I am new to Queued Message Handling or Dynamic Events. I have used these many times before but on a limited need only basis. So it frustrates me to see this much code to do something that can be done more efficiently by a fraction of the code. I don't want to turn this into a rant against DQMH, but I have seen enough of it to decide I don't want to use it.
Without the actual source code, or a complete description of your application (at least a back-of-the-napkin sketch of which modules there are, and how they communicate), it is hard for us to be of much help. The only thing we can claim is what drjdpowell already stated: It's highly unlikely that the problems you're facing are rooted in DQMH itself or in the events/queue functions of LabVIEW.
I have posted a overall architecture picture created with AntiDoc in one of my earlier replies. This picture shows all the DQMH modules and their connections. As I said, this project contains over 2000 VIs, and I am sure no one wants to go through that on this forum! Usually bugs can be localized to one or two VIs then sent to the forum like this, but the weird bugs that I am seeing (random duplication of old data, different data elements arriving out of order etc) cannot be reproduced without running the full project.
I'd be happy to try and help figure this out, but from what you've described here so far, I'm not sure I understand correctly how the modules work together:
  • How are the modules connect? I.e. which module uses which requests of others, which modules are registered for other modules' broadcasts?
  • You're mentioning 15 modules (8x DUT, 1x DAQ, 1x Logger, ...?)
  • You mention 8x 16 channels in one place, but only 1 counter channel per DUT (8 in total) coming from a cDAQ counter module in another place
The AntiDoc picture I posted in my previous post shows the DQMH modules. The 8 DUTs are all cloned from a single module called "Unit Display". Beyond that, there are several additional  DQMH modules. My initial count of 15 was incorrect. It is closer to 20, counting the Unit Display as 1 module.
There are approximately 16 data channels per DUT, but they are mix of different types of signals. Some Analogs (Voltage, Current, Temperature), some LIN, some Bluetooth, some angle measurements. But the two operating events per cycle that I mentioned are detected by a Counter channel. So although there is only 1 counter channel per DUT, it has other types of Channels of data associated with it. All these different data have to be assembled into one record for each operating event. Hence my estimation of 8 DUTs x 16 channels.
4) I was dreading this approach.  Just the suggestion of an Activity Tracker contradicts the supposed robustness of the underlying DQMH architecture!
I find this statement interesting, as I'm of the exact opposite opinion. The very first thing we put in place whenever starting a new project is our HSE Logger (a small, free, open-source logging tool, designed after the Python logging library), which out-of-the-box can log to files or user events.
Since l last posted, I have created and installed an Activity Logger on one of the Modules (Data Formatting Module). This logger records all events received by the Module to a file with timestamp. As I feared it is collecting huge amounts of data (>120MB per day). I have set the logger to start a new file every day. On Monday, I will have the customer send me the log files so I can look through them. I am not new to debugging by any means and I have done my share of logging activity before but that is for capturing hardware or system faults, not for a perceived software fault. Such faults are usually revealed by simulation testing, and conventional debugging methods.
It is quite common - and probably even recommended best practice in most cases - to design your modules in a way that they don't (statically) depend on each other. One way to do that is to design a tree-like structure for how modules communicate. I think that's often mentioned when talking about Actor-based design. Messages sent from one module to another will travel from the sender up the "tree" to a common node, then back down to the recipient.
At first look, the fact that data is routed through a module (or modules) adds complexity to your application. On second look, it also reduces complexity by cutting down on the number of direct connections between all your modules (and thus, helping with cohesion and coupling). There are various methods that can help with adding more transparency to the communication. Logging, as mentioned above, is one method that I feel is definitely worth a look.
Again, if you're able to share more information, we (both the Consortium and the community) would be happy to look into it and try to help solve your issue.
Like I said before, I have been Certified LabVIEW Developer for 15 years. You might wonder why I did not become a CLA. It is because I have very definite notions on software architecture, and my thinking is somewhat counter to what NI expects of CLAs. But in reality I have always been an architect and a developer. To me simplicity, maintainability, performance, robustness come first.  Some vague understanding of future expansion needs and designing the software for that, to the point of becoming a huge overwhelming architecture comes a distant second.
Sorry for the long reply. I will keep you posted on what I find. As you said it is probably unlikely to be a DQMH bug, but the architecture is definitely getting in the way of debugging this.
Message 17 of 42
(1,681 Views)
The code you encountered has some major problems based on the Antidoc diagrams you posted. I wouldn't let that turn you away from DQMH any more than encountering a bunch of spaghetti code would turn you away from LabVIEW.
Is it overkill for some situations? certainly. Just like buying a power screwdriver is overkill if you only need to tighten one screw, but if you already had the power screw driver you'd probably use it and it'd do a perfect job and probably be quicker.  Similarly, do you need a DQMH module if you just need a simple single loop app? certainly not. But if you know how to use it, there is no reason not to.
Sam Taggart
GCentral
Message 18 of 42
(1,675 Views)
Hi LVUser94.
Thanks for posting the Antidoc picture.
As Sam has already suggested, this picture tells us a lot.  There is too many circular dependencies, and there is no wonder you're having some challenges right now.
Unfortunately it looks like you've inherited code from someone new to DQMH, and didn't have the experience to plan out the modules and their inter-relationships with more care.
Based on this picture alone, I would suggest that the application needs to be re-architected.  Whether you still use DQMH or just go with what you know works, that's your call to make.
If you want to continue with DQMH, my recommendation to ensure success would be to enlist one of the Trusted Advisors for a short stint, to help you plan out the new approach.
If you choose the other way, I am confident with your experience you'll make it work too.
I don't envy your position!  I hope you can find a solution.
Christopher Farmer
Message 19 of 42
(1,671 Views)
My advice would be to refactor it.
Decide what the dependency graph should look like.
Come up with some basic test you can run.
Then start changing broadcasts to requests and vice-versa.
Change them one at a time and test afterwards.
Run Antidoc after each one as well just to make sure things are moving the direction that you want.
Not a quick fix, but should work.
May be quicker to rewrite it, but inevitably there's some corner-case logic somewhere that you'll miss that will mess you up and that will cost you a lot of time and make for unhappy customers.
Sam Taggart
GCentral
Message 20 of 42
(1,665 Views)
