Efficient way to use DVR in DQMH modules
Ozfarmboy:
Is the constant allocation/deallocation of memory occurring because DVRs are being constantly created/destroyed going to create a determinism issue?  I am think especially for RT here
I had the similar question, What is the memory allocation/deallocation overheads in very frequent DVR create and destroy option(lets say every 50mS) for 24x7 running application?
Thank you
Message 11 of 21
(1,984 Views)
One additional suggestion for you, in case the data type you stream changes over time, you can typecast the DVR ref into a U32 to make it "embedded-data-type agnostic".
If you do that, when you typecast back from U32 to DVR ref, place the "create DVR" primitive in a disable struct and the data type out of the disable struct 😉
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 12 of 21
(1,958 Views)
Putting the DVR in a Variant is a safer way to do this, in that you wont crash the program if you cast to the wrong datatype (you'll get an error instead).
Message 13 of 21
(1,955 Views)
...and I was wrong to think that the to-variant + variant-to-data would take longer to execute, it's the same!
I hope LabVIEW will find other ways to crash 😮
Epictetus
Antoine Chalons
Message 14 of 21
(1,952 Views)
Any thoughts on this?
Between, Thank you for all your replies, its all great information.
Thank you
Message 15 of 21
(1,920 Views)
My thought is to wonder why you haven't just measured DVR overhead with a simple test VI.  Make and destroy 10,000 DVRs per second and run that overnight.
Message 16 of 21
(1,913 Views)
I already did that. I was wondering, I would get more information, if some one already had experienced with bigger application in this scenarios. The behaviour could be different in bigger applications when there is a lot of thread switching, thermal managing/throttling,  large memory management and etc are happening.
Message 17 of 21
(1,908 Views)
So you are asking if anyone with experience using DVRs in this way has had any problems.  That is a better question.
Message 18 of 21
(1,901 Views)
@Olivier-JOURDAN wrote:
@joerg.hampel  a écrit :
I guess that it's alright to send the DVRs via plain old broadcasts, right? Seeing as it's only the reference we're sending, we don't need to be concerned about the data copies which the event system creates ?
If creating a broadcast with an array in the first module and registering the second module to listen to the broadcast is not performant enough, it's fine to replace the array with the DVR ref. I'm not aware of any data copy doing that.
The trick of option #1 is to set the value when you create the DVR and retrieve it. When you destroy the DVR, you never have to read or write the value.
I too have been thinking about sending a DVR with a broadcast event. My question is: Where should I destroy the DVR?
In DQMH there is a unknown number of listeners to the broadcast. At a minimum there is one parent module and there is one tester and both can run without the other or at the same time.
Is it a must to only listen in the parent to this broadcast and to destroy the DVR in the parent?
What happens to the DVR in case you run the module from the tester? Does the module has to know that it is run from the tester and in this case doesn't create the DVR at all?
Message 19 of 21
(402 Views)
@UliB, IMO, using DVR to share data between modules, should only be used when the classic method can't reach the expected performance.
Without knowing your context, I'd first try to have only one target for my data. The sender module creates the DVR and the Receiver destroys the DVR. You can send the DVR with a broadcast or a request. This choice won't be directly related to the use of a DVR.
If you really need to share data with multiple modules, I would only share the DVR ref once with the target modules, and give the responsibility of destroying the DVR to the module that generates the data.
Of course, ensuring that all modules receive and process all the data will require some handshaking at some point.
As I said at the beginning of my message, if you need to use DVR, you may have constraints I'm not aware of, so take my message as it is, just some basic thoughts on hox to proceed and first make sure you really need a DVR 😉
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
Message 20 of 21
(334 Views)
