DQMH Consortium Toolkits Discussions
How does the "Convert DQMH Event" tool work?
From the name and what I observe, I assume it works in a way that allows me to select any event from my module and change its type to any other type. However, based on the list of available requests, it seems that I can only convert events into the "Request and Wait for Reply" type, or there is some filter limiting the visibility of other events. Generally, in the list of events available for conversion (dropdown list #2), not all events are listed, and in dropdown list #3, I can only choose one specific type to convert to.
How should it actually work?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(883 Views)
Accepted by topic author bienieck
You can only convert from a Request to a Request and Wait for Reply event.
Converting an Existing DQMH Event :: DQMH Consortium Docs
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
DQMH Trusted Advisor
Automated Production Test Specialty Premier Partner
https://wiredinsoftware.com.au
(857 Views)
That's a pity 😔
Michał Bieńkowski
CLA, CTA, CPI
(844 Views)
Some improvements will be in DQMH 7.1 --> https://documentation.dqmh.org/dqmh/7.1/ConvertinganExistingDQMHEvent.html
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
(829 Views)
